Attenuate pitch wheel (Voyager Old School) ?
Any thoughts on how one might limit the range of the wheel? Just curious. I've tried a few permutations with the VX-351, but I'm not sure it's possible.
Re: Attenuate pitch wheel (Voyager Old School) ?
Perhap SteveD can offer some assistance here.18watt wrote:Any thoughts on how one might limit the range of the wheel? Just curious. I've tried a few permutations with the VX-351, but I'm not sure it's possible.
Not specifically addressing your issue, but related, this bit of information regarding Pitch Bend appears in the Old School User's Manual (in case you missed it):
Pitch Bend: This spring-loaded performance control affects the pitch of all three oscillators. The pitch bend amount is fixed at +/- 2 semitones (one whole step). The Pitch Bend amount is set by an internal jumper. Although most players will be comfortable with the factory default setting (+/-2 semitones), wider ranges can be set by reconfiguring an internal jumper. For details on this procedure, visit the Voyager Old School section on the Moog Music web site (www.moogmusic.com).
Sounds like they misplaced the jumpers on your instrument. No big deal, because it can be adjusted, but it is a Global adjustment that affects all patches.18watt wrote:Aha! Thank you, I did miss that! Mine's set at waaay more than two semitones...
*wanders off to go count*
OK, mine's set at seven semitones, which is great for some stuff, but less for others. It's really not a big deal, but it'd be cool if one could tweak it externally.
FWIW, the Model D Minimoog PB range was also fixed, albeit at a smaller range.
Update on the Old School PB Range
FYI: According to Steve Dunnington, the Pitch Bend range of the Voyager Old School was changed from a planned +/-2 semitones to a wider +/-7semitones just prior to production. This changed was based on feedback from some heavy Minimoog players who favored a wider PB range.
The change was made after the User's Manual went off to the printer, which is why the manual states "+/- 2 semitones".
The good news is that the PB range can be changed via a jumper, so no one is stuck with an undesireable setting. A tech note on performing this mod is planned.
