wait and listen.....NAMM
- latigid on
- goldphinga
osc, sync, env, fm. awwww yeah!@!!!!!Jebus0000 wrote:http://moogmusic.com/forum/viewtopic.php?t=3933
www.ctrlshft.com
Wow, this looks really great, and very close to what many people on this forum have been speculating after for a long time. I really like this audio signal freq modulation of the VCO. I've found it difficult to modulate a VCO from an irregular and low level audio signal like a guitar. But the frequecy modulation on the teaser track sounds great, so I'm really excited about trying this out.
But there are three things about this 107 that seem strange to me, not bad, just strange:
1.There's no pitch/frequency tracking of the input signal. It would seem that P/V circuits are just not a viable control source (none of the ones I've used work very well). Or else, it would seem like they would be the natural solution for controlling this oscillator.
2.There's an Envelope Follower instead. Just a little redundant if you already have the MF101.
3.There's oscillator sync, but only one oscillator. Maybe all that is needed for an oscillator to sync is a seperate internal clock source-- but I've never seen this before.
maybe it syncs to the incoming signal? i'm not sure what the FM feature would do if this was engaged, but it'd be a pretty good bet that the sync locks the VCO to the ext signal. i bet this fooger also has a SYNC IN on it, so you can sync with other oscs while still using an ext signal. in that instance, the FM feature could employ some seriously awesome modulation.eric coleridge wrote:Wow, this looks really great, and very close to what many people on this forum have been speculating after for a long time. I really like this audio signal freq modulation of the VCO. I've found it difficult to modulate a VCO from an irregular and low level audio signal like a guitar. But the frequecy modulation on the teaser track sounds great, so I'm really excited about trying this out.
www.ctrlshft.com
Maybe you know more about this than I do, but I believe you need a square/pulse-like wave to sync an oscillator.CTRLSHFT wrote: maybe it syncs to the incoming signal?
If there was some way for the VCO to sync to the input signal, this really will be a very remarkable VCO--- one that might track the input pitch without a normal P/V circuit. But I think this would be the first thing they mention if this was the case. Instead they seem to be celebrating the frequency modulation aspect.
Audio frequecy modulation of a VCO is alot like Ring Mod, and is probably what all ring mod type sounds are in the track. I cant wait to try it out
my tech knowledge on this stuff is rather topical unfortunately, you may be right. regardless, i think this unit is going to be revolutionary in some way.. moog has a tendency towards awesome.eric coleridge wrote:Maybe you know more about this than I do, but I believe you need a square/pulse-like wave to sync an oscillator.CTRLSHFT wrote: maybe it syncs to the incoming signal?
www.ctrlshft.com
definitely. I've been wanting a discrete Moog VCO like this for ever to patch into my other synths. But it's a little curious that there's no octave select or waveform legend. I hope that the VCO is more than a square/pulse. But whatever, it looks and sounds great.CTRLSHFT wrote:regardless, i think this unit is going to be revolutionary in some way.. moog has a tendency towards awesome.
ditto! whats the deal with skipping a number? also, how has the 107 leaked and the 106 not if there is a 106 in the works (presumably) simultaneously?OysterRock wrote:No pitch-to-CV on the 107.
Hmmmmmm....I wonder what the 106 is...
i'll hold my tongue until NAMM, but theres some exciting things afoot!
www.ctrlshft.com
