earsmack wrote: So an idea I thought about...what if the existing input jacks were converted in a way that allowed them to work both as inputs and outputs? I'm no electrical guy but my thought is this:
Is it possible to change those jacks to internally work maybe like a patchbay - or maybe with some "special" plugs like Apple uses on iDevices where there is not only audio but also control data being sent via the one input/output. Imagine if the Filter input was also the output. If done how I'm thinking you could use off-the-shelf 1/4 stereo male to two 1/4 mono adapters, one would be the input and one would be the output. Moog could "brand" some of these cables with proper coloring to avoid the guesswork of which is which. If you plug a normal mono jack in maybe it works as it does today (input CV only) so I can still easily plug my pedals in without one of the Y adapters if I don't want the output capability.
Make sense?
This would require no new holes being drilled, no new plastics (or woods) and only internal changes to the components - which I'm assuming is on a board that could be swapped out by the user.
My $.02 and would be much cleaner in my opinion.
I like that idea my Rogue is that way and it works fine.
