I will probably get a llarger case but I want to get solid oscillator with a lot of options, definately a loss pass gate (probably Doepfer's), here are some others I would like to get:
http://www.cwejman.net/res-4.htm
http://www.cwejman.net/fsh-1.htm
http://www.cyndustries.com/modules_zero-osc.cfm
I also like some of the wasp and borg filters and a few others I see out there.
Frequency to CV Conversion
don't forget the polivoks!Lux_Seeker wrote:I will probably get a llarger case but I want to get solid oscillator with a lot of options, definately a loss pass gate (probably Doepfer's), here are some others I would like to get:
here's a mp3 demo
www.ctrlshft.com
I will use Analogue systems rs-35-pitch to CV,AS LPF(for tracking filter-it cuts high freq.for better tracking),AS Cable adaptor(for converting cables), doepfer multiples,doepfer VCA. The Multiples and cable adaptor dont need case or power,so that will be outside...I will make a wooden mini case for them.ColorForm2113 wrote:what modules are you putting in the mini case, other than the pitch>cv of corse? I like those minicases I think that was a really great idea on their part to get people introduced to modular stuff. I eventually want to get a mini systems and pitch to cv might be the way to go.Vitja B wrote:I will build a pitch to Cv system out of doepfer and Analogue Systems moduls and doepfer miniature case. I just hope It could track ring modulator and filter.
Than you have much more to explore.
That is good start for me...I hope I could track ring mod and filter.
I think is good idea for guitar to have a tracking filter,so it follows your pitch and you get always the right cutoff,no mater what are you playing,high notes or low...
I hope I could make a tracking ring mod.But I thing this will work best with another oscilator going to MF-102s carrier in...if you detune it you can get limitless timbers.
Anyone familiar with this app. Is all this possible?
MF-101,MF-102,MF-104Z,MP-201,PRS Custom24/10 top,Acoustic G100T,many more.
I could be missing something here but if you carrier in is a ptich track oscillator via the pitch to CV module then this should work right? There are also modules that will do frequency shifting.
Something like this might help:
This can also do ring modulation but you shoudl also be able to use it to shift the frequency slightly of the CV going to the carrier in of the fooger.
