Hi!
I bought the second-hand Moog Little Phatty Stage I and it looks like it has a problem with the pitch wheel. When I connect it through MIDI, without touching anything there are random pitch bend messages. Also I can see that during the procedure CALIBRATION PITCH WHEEL that the wheel itself has some free movement on the middle , changing the parameter from 2058 to +-10 cents.
I made all of the calibrations after the 30 minutes warm up. But the problem does not go away.
Any idea?
Thanks!!!
Little Phatty pitch wheel problem
- stiiiiiiive
Re: Little Phatty pitch wheel problem
These are not "cents" but just 10 MIDI values out of 4096, no worries. Mine does it too, I mean the calibration shaking value. I don't use it via MIDI thugh, so I can't say whether it sends this or not.
- stiiiiiiive
The exact same thing
Thank you !
