New product @ Musik Messe!!!
new Moog at Frankfurt
Hi All !!!
I know exactly what it is..
A 256 Note polyphonic Voyager with multiple touch pads, 32 individual outputs, 256 note step sequencer, multiple arpeggitor, and optional Theremin Pro hardware bay.
See you all at the Messe !!
Re: new Moog at Frankfurt
Damn!!!Lewis wrote:Hi All !!!I know exactly what it is..A 256 Note polyphonic Voyager with multiple touch pads, 32 individual outputs, 256 note step sequencer, multiple arpeggitor, and optional Theremin Pro hardware bay.
Don't hold back brother. We feel YA!
THE ULTIMATE MOOG MACHINE!!
Don't forget:
Unlimited poly expansion, 128 bit effects section + multiple analog effects resouces (including real spring reverb and the entire Fooger effects design resources), built in stand, Wavetable synthesis (Some of us synth fools now how cool that is ) and a bag of BC buds (only available to North American customers) to enhance the experience .
What did I forget?
Beam me up Scottie...Hi All !!!I know exactly what it is..A 256 Note polyphonic Voyager with multiple touch pads, 32 individual outputs, 256 note step sequencer, multiple arpeggitor, and optional Theremin Pro hardware bay.
Don't forget:
i'd prefer just a small simple monosynth that sounds cool
where do you think they'll put this new product on the website?
they currently have sections for
minimoog, moogerfoogers, etherwave, pianobar, etc
do you think they'll rename the minimoog section to synthesizers
or
do you think this new synth will be a minimoog, just not a minimoog voyager?
eg: the minimoog adventurer
or
do you think they'll put up a new section?
or
or
Anyway here is a blog I've posted on my myspace site.
Then I found this forum and this thread, you may have some thoughts reading my guess.
Check it out :
Friday, March 10, 2006
Thoughts about new moog thing.
Current mood: calm
Today I've seen a pic of moog music announcing a hint about their new product.
From that led-ringed knob, moog's blusterous advocacy, and this post :
http://www.retrothing.com/2006/01/a_low_cost_moog.html
I guess it is likely to be a synth with programmable analog chip.
If that's true, I'll really admire the RD department of moog music. That programmable analog technology is totally impressive to me, an Revolution after DSP processing. It means all the analog circuitry can be altered with code, like all the flexibility that DSP offers combines with true analog signal path. Think about a vast collection of different real analog compressors/eq/synth inside one box, changeable with a few button presses.
Possibly Moog does become the pioneer of synthesizer technology again, with their asset, other small new companies can't impliment a new synth technology available in products, as fast as moog can. Another company I know that's working on the programmable analog synthesizer is called Sonoric(See http://www.sonoric.nl). Very cool product design and from holland(not many synthesizers was from there). I will just look into the moog's new thing and this small new company to decide which I will get, tho I lean more on the Sonoric synth. Cos there must be tons of sells from moog, I don't feel quite good to be one of those ppl. Might sounds a bit wired but I don't like to use a simple thing that many ppl are using, it is easy to sounds similar, even without conscious.
Feel free to visit my myspace page, the url is
http://www.myspace.com/mengqi
Peace.
Check it out :
Current mood: calm
Peace.
My Space Page:
Isn't it the same way the Alesis Andromeda is designed?
Regards
Demokid
Regards
Demokid
Gearlist: Andromeda A6, Emu E4XT Ultra, Korg MS20, Minimoog Model D (incl.MIDI), Minimoog Voyager AE, Roland Jupiter-8 (MIDI), RE-301, Prophet~5 (Rev3.3 incl MIDI), Poly Evolver Keyboard, Pro~One, Prophet 08, Synthesizers.com Custom Studio-44
I know exactly
I know exactly what it is..because of its proximity to St Pattys Day its a mooger-type box with a little Leprechaun inside of it that makes all these strange little analog noises when the thing is plugged into an amp. you can dial in any of his 256 separate sounds from the little elf and either layer them and save them for further use or patch them right into your voyager ... well since theres so many hairbrain suggestions, why not add one more? stop the madness, we'll all know soon enough, huh?? LOL
Ok but they have a picture of the Andromeda on there webpage so I thought they used an early version of the chips.
Regards
Demokid
Regards
Demokid
if they used those super IC things, does that mean they could make a small self-contained modular synth with memory?!!
if they do use these things I can imaging that the status between the voyager and the new synth will be like the status between the model D and source or multi
MULTI/SOURCE
pros
- more features
- lower cost
cons
- doesn't have "the" mini sound
MODEL D
pros
- has "the" mini sound
cons
- expensive
- less features
NEW SYNTH
pros
- more features
- lower cost
cons
- doesn't have "the" mini sound, from the discrete components
VOYAGER
pros
cons
- expensive
- less features
MULTI/SOURCE
pros
- more features
- lower cost
cons
MODEL D
pros
cons
- expensive
- less features
NEW SYNTH
pros
- more features
- lower cost
cons
VOYAGER
pros
cons
- expensive
- less features
do you think that the LEDs on the knob could represent different functions of the each chip?
probably not but hey.
do you think they could have a whole synth full of those rotary encoders (memory knob things) if the cost of the synth sound components was reduced by using the IC things
if that didn't make sense:
have a cool LED knob for every parameter (rather than just one general data control like on the source)
so... we're all pretty convinced this is a cheaper Moog monosynth, right? especially after reading those articles... but we are speculating off of our own speculation which is being fed back to us from an article that we influenced. hah! awesome.
I really hope it is a cheaper monosynth. I'd love to have something more reliable than my mg-1 and source live. If so, I wonder how much cheaper it'd go for(?). Someone a few pages back mentioned it maybe having those smaller-sized keys (like the microkorg), and if so, i'll be heart broken. i dont htink they would, but if moog ever did that i wouldn't even think about buying it. i have giant fingers. i could live with 2.5 octaves though
I would actually love to see a mix a mix of digital and analog, like the waldorf Q (not that the Q sound very authentic analog). If the oscillators were digitally reproduced, and the filter was analog moog, the sound quality could be very close to the real thing. Creamware has shown us that it is possible to create wellsounding digital clones of the old analog monosynths. VSTs have a bad rep, (or should have a bap rep anyway) because they do fall short of the real thing (by quite a big margin) - like minimoog V or Minimonsta.
If we got something digital that had the quality of Minimax (incl. less static attack), using real moog filters, damn..that would be great. Of course in a beatifully design casing like the original model D or voyager. I think actually I would prefer that to a "crippled" voyager, if the sonical comprimises will be to great (like only having 2 osc. and a less powerful/distinct sound).
I'm not saying that analog is to be done away with, but this would be a keyboard that I would buy for sure.
Otherwise, I would love a barebone (=less expensive) minimoog D mkII synth with the new moog technology, with oldstyle portamento/filter. It would for sure be a huge mistake IMO to offer a synth with a smaller keyboard that 3.5 octave. Not all people use minimoogs for techno dablings and bassriffing, some actually use them as a lead instrument... (sarcasm alert..)
Anyways, I'm really curious to what moog will release. We really don't know if it will be a synth, but my gut feeling says so...
