Copy all settings from one Minitaur to another?
jessemiller
Post by jessemiller » Tue Dec 13, 2022 8:04 pm
I'm probably missing something, but I'm not seeing an easy way to copy all of the internal presets on one Minitaur to another. Anyone know best way to do this so I can have a backup with the same presets?
stiiiiiiive
Re: Copy all settings from one Minitaur to another?
Post by stiiiiiiive » Wed Dec 14, 2022 9:00 am
Isn't there a sysex "dump all" function on those bichos?
till
Post by till » Thu Dec 15, 2022 6:26 am
If you send this SysEx (notated in hexadecimal numbers here) to the Minitaur, it will send out all patches as SysEx:
F0 04 08 06 00 00 00 00 00 00 00 00 00 00 00 00 F7
Sequence:
jessemiller
Post by jessemiller » Fri Dec 16, 2022 12:16 am
Any suggestions on best method to send and record sysex at the same time? I'm trying to send via Max and record with Sysex librarian, but I don't seem to be getting the message format correct in Max. Trying to use sxformat object. Maybe there is a more simple method?
till
Post by till » Fri Dec 16, 2022 5:31 am
I built myself a very simple self made App to send out small SysEx strings. And I use SysEx Librarian on my macOS to record the received Minitaur SysEx patches.
Download and use at your own risk: https://till-kopper.de/soft/index.html#midi-sender
And as I am not a certified macOS developer (cost me too much), you will get a macOS message about telling you about this.
Sequence:
jessemiller
Post by jessemiller » Fri Dec 16, 2022 11:15 am
ummagumma
Post by ummagumma » Fri Dec 23, 2022 2:38 pm
Hey that's cool! Thanks Till!
