Hallo,
i have an issue with a MF-105m which i got last week.. not sure if the LFO-behaviour is normal or not.
In Pattern nr.1 (stativ Filter) the LFO is about 9 seconds per one cycle, so very slow.
If i plug a cable into the LFO-CV input and unplug it the LFO is up to approx. 1 second per cycle.
If i change Switch Mids/Bass back/forth or Pattern back/forth the LFO goes back to 9 seconds per Cycle.
Is both of that normal?
Per Software i was able to change LFO speed for pattern 2 to 24. But in the Pattern window there is no possibility
to adjust Pattern one (because obviously it has no pattern). But is it possible to adjust the LFO speed of Pattern 1
and save that as default somehow?
thanks & best regards
patilon
Murf MF-105m LFO issue
Re: Murf MF-105m LFO issue
hmm, any murf-owners here?
- stiiiiiiive
Hey Patilon!
Yep... but I'm all packed for now, just moved away and there's a lot to do here. I'll check that asap, which means within a coupe of weeks though.
Anybody else meanwhile?
thank you stiiiiiiive!
hope someone´s gonna jump in
hello i;m sitting in front of my 105 m ,but i do not know how to try it what you mean! i;m not a profi,but if you explain it or give me a step by step process i will try it
