Page 1 of 2
New LP Stage user here!
Posted: Mon May 07, 2007 5:09 pm
by Array
Picked up my LP Stage Edition yesterday, #16. It's everything that I had hoped for
One thing that sort of caught my eye is the fact that the headphone jack looks slightly malformed, but this has no effect on operation. Anyone else have weird looking headphone jacks?
Posted: Mon May 07, 2007 5:17 pm
by goldphinga
weird in what way? can you post a pic?
Posted: Mon May 07, 2007 5:22 pm
by Array
I'll try and take a picture tonight.
Posted: Wed May 09, 2007 11:43 am
by cl516
cool, Array!
I'm #666 myself.
didn't u used to be on a few other synth forums too?
FWIW my headphone jack doesn't look deformed.
Posted: Wed May 09, 2007 2:00 pm
by Array
cl516 wrote:cool, Array!
I'm #666 myself.
Haha, I didnt know that they even made 666 of them!
I used to be on other forums, but they got stale. I keep to forums related to products I own now.
Also, here is a photo of said headphone jack:
http://img509.imageshack.us/my.php?imag ... 814fc6.jpg
Looks normal
Posted: Wed May 09, 2007 2:20 pm
by LilFatty
that is how my jack looks on my LP TE.
Re: Looks normal
Posted: Wed May 09, 2007 2:27 pm
by Array
LilFatty wrote:that is how my jack looks on my LP TE.
Cool, thanks for the feedback. It's no big deal, just a little off center.
Re: Looks normal
Posted: Wed May 09, 2007 5:03 pm
by sergiovalente9
Array the same here. I have TE #SE00376 last week, and has the same Jack.
This is my first hardware synth (and the first SE sold in Argentina) and I´m very happy. U can play very easy and sound greeeeeeeat! I used Arturia VST but Little Phatty is really better.
Posted: Wed May 09, 2007 5:21 pm
by robles
It looks as though the washer isn't perfectly centered. Other than that, I'm not sure what's wrong with it. When you plug a line into it, is it straight, or skewed diagonally?
Re: Looks normal
Posted: Wed May 09, 2007 5:47 pm
by Array
sergiovalente9 wrote:LilFatty wrote:that is how my jack looks on my LP TE.
Thanks for the confirmation
While not my first hardware synth, the Little Phatty is definitely a much welcomed addition.
Posted: Wed May 09, 2007 5:48 pm
by Array
robles wrote:It looks as though the washer isn't perfectly centered. Other than that, I'm not sure what's wrong with it. When you plug a line into it, is it straight, or skewed diagonally?
It's straight when I plug in a line, a purely cosmetic issue. I just wanted to know if there were others with such jacks.
Posted: Wed May 09, 2007 6:33 pm
by robles
Just loosen the nut slightly and center the washer, then tighten again.
Posted: Thu May 10, 2007 12:14 am
by cl516
hmmm yeah yours looks off centered, Array.
Mine isn't like that, it's centered.
As for the other forums, yeah some of them have gotten quite off topic and... well, just plain 'mean' sometimes. They're not so cool at times.
Posted: Thu May 10, 2007 7:16 am
by Amos
robles wrote:Just loosen the nut slightly and center the washer, then tighten again.
yep, that's clearly all it is.
Posted: Thu May 10, 2007 6:00 pm
by theglyph
WARNING!!
Be very careful with this. The nut is tightened quit snug at the factory. If you try to loosen the nut without holding the jack internally the nut can spin the jack, twist the wires internally and pull the connector off the PCB. Trust me, i've done this once or twice.
It may be possible to loosen the nut but if it looks or feels like the jack is spinning as well, stop!
Here's some advice if you must align the washer.
NOTE that opening the LP can void your warrenty! You can remove the screws from the right hand side panel, set the panel and side plate aside, carefully reach in and grab the jack but DO NOT touch the circuit board next to the jack, hold the jack firmly and then loosen the nut. Put everything back like it was when satisfied but be careful to align the side panel screws with all of the holes and put the right screws into the right holes.
Another bit of advice when doing this is to ground yourself using a ground strap or at least make sure you are static free by touching a metal surface before reaching into the LP's side. ESD (electro static discharge) can damage the internal components. Avoid contact with the PCB's like the plague.
