Page 23 of 23
Re: New Firmware v3.1 for Slim Phatty, LP Stage and Tribute
Posted: Sat Aug 13, 2011 7:56 am
by dualaud
I don't want to double post, so I'll just link my report of what *may* be a bug in OS 3.1 in connection with the CV out mod.
Mod Bus out stops outputting after 30 seconds.
dual
Posted: Fri Apr 06, 2012 4:08 pm
by Sore_Knee
I'm not sure where to raise this, so i'll post it here. i think i've found a bug, only slight, but it is strange behaviour.
LP SII, i selected preset 52, set the appeg to latch. as i turned the modulation knob to change the speed of the clock, the LED dial about the EG knob began to flicker between the very-most-minimum LED and the actual set LED.
the actual sound didn't seem to be affected.
Posted: Sat Apr 07, 2012 1:35 am
by Sir Nose
Sore_Knee wrote:I'm not sure where to raise this, so i'll post it here. i think i've found a bug, only slight, but it is strange behaviour.
I have seen similar behavior when sequencing parameter changes via midi CCs. I blamed it on the sequencer sending extra data. I forgot which ENV parameter was jumping, I think AMP attack. It is only ever in the envelope section and the same parameter. I wonder if it has any thing to do with the added velocity to amp. It was audible when I encountered it.
Posted: Tue Jul 03, 2012 5:53 pm
by fuzulu
Posted: Wed Jan 25, 2017 12:16 pm
by LittlePhattyTribute
Hi Guys,
hoping someone could help me out! So I made a fatal error and tried updating from 1.04 to 3.1 on my LP tribute... It got messed up and now im stuck with Search for USB Module and can't do anything else. Tried getting the 1.04 firmware back on it but all fails... Do I need a USB Debugger or is there another way?!
Help would be greatly appreciated!
